Hello
I am trying to pull data from Dataverse into Pinecone. When I run the flow, I get the connected errors. Doing some look up, it looks like the input may not be sending some elements, but it says it is, and my output shows it is. Any thoughts on how I can resolve
What does your script look like?
I have not entered any script. This just the connectors out of the box
I ask because the error is coming from the script and I see the hook icon there with a preMap script. Are you saying you got this from the marketplace?
No, I know what you are asking now. I worked with the internal AI tool yesterday and removed these errors. As you mentioned, I need to make some tweaks to the preMap and resource mapping scripts. Now on to solving why the embedding is not happening.
