Hello,
When referencing a custom setting in the additional search criteria window like so:
We receive the following error:
I just want to confirm; there is no way to access custom form settings from additional search criteria?
Hi @friendoftuesday,
The error occurs because custom form settings are currently not supported in the additional search criteria.
Could you please clarify your specific use case for referencing the custom form setting in the additional search criteria, instead of using values? If it's essential to use custom settings, we can explore alternative solutions to address this.
Hello @praveenbasani ,
Thanks for your response.
Here is the flow context: Inventory levels are being exported from NetSuite for a storefront. Rather frequently, the locations and inventory statuses that should be displayed on the storefront need to be adjusted. Thus, we were trying to provide a simple way for non-technical users to toggle exports on/off for certain locations and statuses.
There are two workarounds that I have identified:
The former requires additional developer upkeep due to the additional script, and also increases processing time because many unneeded records are exported and processed. The latter increases the potential for errors due to the precise way values must be entered. Thus, using a custom form setting directly in the additional search criteria is the ideal solution, but it is not essential.
