@sujitdesai183, on another note, this refreshable setup is limited to 100 options in the drop down list. If you need something with more than 100 options, you can flip to form script and it will allow a lot more than 100 (not sure the exact limit). Here is a sample script that does the same thing as this form JSON, but allows more than 100 options per drop down. You will have to update the connection ids to your own. Again, we're working on updating documentation, but hopefully this is helpful for you and others.
import {
connections,
integrations,
exports,
imports,
flows,
request
} from 'integrator-api'
class Form {
// { fieldMap: {}, layout: { fields: [] } }
constructor() {
this.fieldMap = {};
this.layout = {};
this.layout.containers = [];
fields(...fields) {
this.layout.fields = fields;
container(type, label, ...fields) {
this.layout.containers.push({
type: type,
containers: [{
label: label,
fields: fields
column(label, ...fields) {
this.layout.type = 'column';
label: label,
fields: fields
class Field {
constructor(id, name, label, type) {
this.id = id;
this.name = name;
this.label = label;
this.type = type;
isRequired() {
this.required = true;
canBeDeleted() {
this.showDelete = true;
isMultiline() {
this.multiline = true;
description(description) {
this.description = description;
help(helpText) {
this.helpText = helpText;
typeOfInput(type) {
this.inputType = type;
default(defaultValue) {
this.defaultValue = defaultValue;
delimiter(delimiter) {
this.delimiter = delimiter;
keyNamePlaceholder(keyName) {
this.keyName = keyName;
valueNamePlaceholder(valueName) {
this.valueName = valueName;
mode(mode) {
this.mode = mode;
addOption(arg1, arg2) {
if (!this.hasOwnProperty('options')) {
this.options = [{
items: []
if (arg2) {
this.options[0].items.push({
label: arg1,
value: arg2
} else {
this.options[0].items.push(arg1);
addStaticMapOptions(keyName, keyLabel, keyOptions, valueName, valueLabel, valueOptions) {
this.keyLabel = keyLabel;
this.keyOptions = keyOptions;
this.valueLabel = valueLabel;
this.valueOptions = valueOptions;
function formInit(options) {
let form = new Form();
// reference: https://docs.celigo.com/hc/en-us/articles/360059205112-Common-form-fields
// deconstruct form to make access to fieldMap for prop assignment simpler
let { fieldMap } = form;
//create field for staticMap
fieldMap.refreshable = new Field('refreshable','refreshableName','label this', 'staticMap');
let keyOptions = getKeyOptions();
let valueOptions = getValueOptions();
fieldMap.refreshable.addStaticMapOptions('extract', 'extractLabel', keyOptions, 'generate', 'generateLabel', valueOptions)
fieldMap.refreshable.description('Map your NetSuite locations to Shopify locations.');
fieldMap.refreshable.isRequired();
//set the layout for the form
form.fields(...['refreshable']);
// wrap up by assigning form to options.resource.settingsForm prop; return the form as well
options.resource.settingsForm.form = form;
return form;
function getKeyOptions() {
return exports.runVirtual({
"export": {
"name": "Lookup",
"_connectionId": "626168f90b6ef816b50c82d7",
"apiIdentifier": "ea7da9f678",
"asynchronous": true,
"oneToMany": false,
"sandbox": false,
"netsuite": {
"type": "restlet",
"skipGrouping": true,
"statsOnly": false,
"restlet": {
"recordType": "location",
"searchId": "2597",
"useSS2Restlets": false
"distributed": {
"useSS2Framework": false
"distributed": {
"disabled": false
"adaptorType": "NetSuiteExport"
}).data;
function getValueOptions() {
"export": {
"name": "Get Locations",
"_connectionId": "62d95e8be26de11b5ee0dba6",
"apiIdentifier": "ede0fb0635",
"assistant": "shopify",
"oneToMany": false,
"sandbox": false,
"assistantMetadata": {
"resource": "locations",
"version": "v2",
"operation": "retrieves_alistoflocations"
"http": {
"relativeURI": "/locations.json",
"method": "GET",
"successMediaType": "json",
"errorMediaType": "json",
"formType": "assistant",
"paging": {
"method": "linkheader",
"lastPageStatusCode": 404,
"linkHeaderRelation": "next"
"response": {
"resourcePath": "locations"
"rest": {
"method": "GET",
"resourcePath": "locations",
"pagingMethod": "linkheader",
"allowUndefinedResource": false,
"transform": {
"type": "expression",
"expression": {
"rules": [
"extract": "id",
"generate": "value"
"extract": "name",
"generate": "label"
"version": "1"
"version": "1",
"rules": [
"extract": "id",
"generate": "value"
"extract": "name",
"generate": "label"
"adaptorType": "RESTExport"
}).data;
