Hi people, how are you?
I am trying to setup a additional search criteria in Celigo but the fields from saved search (created by Netsuite) are not available to create the filters. For example in the saved search there is the "Subsidiária" field but it not appear to create a criteria.
Thank you all,
Danilo
Hi @danilomarques,
If I'm understanding your question correctly, you're exporting data from NetSuite via a saved search, and when you attempt to add additional search criteria:
The fields available in the additional search criteria need to be refreshed.
If you try that and are still unable to see the fields you expect, please open a support ticket or attend an office hours session.
Tom
