Cloning flow from Sandbox to Production fails (redirects to 404)
I tried cloning a flow from Sandbox to Prod on the EU platform.
I followed all the steps and configured the connections (using existing Prod connections). But after completing the setup, I’m redirected to a 404 page, and the deployment doesn’t go through.
Is anyone else experiencing the same issue?
Hi @nuriensing ,
We appreciate you reporting this.
I attempted to reproduce the Sandbox → Prod deployment on EU and wasn't able to trigger the 404 so far. Can you try once again and let us know if it works fine now? It might be an intermittent issue.
That being said, I've reached out to our teams internally to further investigate and you should hear from us when we have something concrete.
Thank you,
Atinav
Same problem, I tried in Brave and Chrome.
Cloning in the same environment works. Only from Sandbox -> Prod not.
Hi @nuriensing - We're having a look internally and we'll keep you posted. Again, thanks for letting us know about this issue.
No worries, if you want me to test it, happy to.
Hi @atinavbajaj23
Do you have any updates on this? The issue is still persisting on our side:
