Channel Advisor to Netsuite Integration
We are just starting out with Celigo and are already stuck. Has anyone ever done the Channel Advisor to Netsuite integration? My main question is will each Channel Advsior profile(country) be a separate integration? For Example Channel Advisor US would be 1 connection with 12(I think) flows in it, then Channel Advisor UK would be another connection with another 12 flows?
Does this sound right?
Hi Dave,
Based on the ChannelAdvisor API documentation(links below), a single connection should allow you to integrate with multiple ChannelAdvisor profiles.
https://developer.channeladvisor.com/authorization/working-with-multiple-accounts
https://developer.channeladvisor.com/working-with-orders
