I have an HTTP export calling a SOAP web service and an xpath statement to access the records in the response:
XML Data from web service:
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope
xmlns:soap="http://www.w3.org/2003/05/soap-envelope"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<aa
xmlns="http://tempuri.org/">
152561087
152580890
XPath:
/*[local-name()='Envelope']/*[local-name()='Body']/*[local-name()='aa']/*[local-name()='bb']/*[local-name()='Data']/*[local-name()='cc']
Yields:
"page_of_records": [{
"record": {
"xmlns": "http://tempuri.org/"
"OrderId": [{
"_": "152561087"
"record": {
"OrderId": [{
"_": "152580890"
OK, great, so that is working. Now I'm trying to load the same exact data, literally the web service response stream from PostMan saved to xml file, but I can't figure out what the Xpath should be in the FTP Export. You'd think it would be the same Xpath as the HTTP export, but no, it's not. I've been at this for hours trying to figure out what Celigo is expecting for the FTP resource path to be.
I've tried the XML parser tool in the dev playground with the same results.
