I can't find the help UI controls at the top. Where are they?
@steveklett what browser are you using? Also, any ad blockers?
I'm using Brave, which is basically Chrome. Brave blocks ads and trackers. I tried turning off Brave's blocking features (it's a single UI control, very cool) and I see the help icon down but the "AI" thing.
(not shooting the messenger...)
Don't love this update: I need to disable my privacy controls to use help and the help has been moved from a perfectly logical location up top down next to the stupid "AI" feature that I avoid whenever possible.
Integrator.IO isn't an eCommerce site. The whole "lower right corner" for chat or help UX design is common on those sites. Integrator.IO is a web-based TOOL and the help should be in a logical location with other UI controls.
Who wanted this change? Did a single user ask for this change? I bet not.
In Chrome with uBlock Origin the new help popup is also being blocked.
@steveklett @basvanditzhuijzen we will be reverting the change and removing the bottom right help button. Will update when I have an eta.
No worries, I've got notifications turned on for the 'troubleshoot custom flows' forum in the hope of finally beating you to a question to answer :-)
word...
@basvanditzhuijzen He has to sleep sometime; shoot for the 1am to 6am (UTC-6) window :)
@steveklett I'm on UTC-7 now so I may still be awake 1am UTC-6 :)
@steveklett @basvanditzhuijzen should be reverted in an hour or so.
