Maybe I'm losing it, but I'm sure the script editor used to have a different layout and there were controls to change between two preset layouts. Now I only have the 3 column layout which doesn't work well without adjusting all the panels to increase the script code window.
It used to be like this, what happened?
@steveklett you're not completely losing it :). For many editors, there wasn't always a layout switcher. For example, transform scripts have the layout switcher, but preSavePage scripts don't. You've noticed it recently (since Nov release I think) because the default layout across the platform changed to the 3 panels.
The good news is that this should (barring it gets deferred) get fixed in April. The April release should include layout switching for all editors and allow you to set your preference.
@tylerlamparter - Cool, thanks for letting me know there is relief on the horizon :)
