Understanding NetSuite Payload Requirements for Partial Fulfillment of Serialized Kit Items
Problem Statement
I am unable to create a partial Item Fulfillment for a Sales Order that contains Kit/Package items with Serialized Inventory.
Despite providing all required sublist details, including item-level information, serial numbers, and quantity assignments, NetSuite is not accepting the partial fulfillment request.
To help troubleshoot, I have attached all relevant screenshots, as well as dummy request payloads and sample data that replicate the issue.
The expected behavior is that NetSuite should allow fulfillment of only a subset of the kit components or quantities, but the fulfillment attempt consistently fails or rejects the partial data.
I need assistance understanding:
  • What specific data or structure NetSuite requires for such fulfillments,
  • And how to correctly prepare the payload to successfully create a partial Item Fulfillment.
  "orderId": "SO52",
  "purchaseOrderNumber": "2000004204",
  "shipDate": "2025-10-24T19:04:57.000Z",
  "facilityName": "W2G (L) - Memphis",
  "customerName": "ABC",
  "shippingSpeed": "Economy",
  "OrderDetails": {
    "skuQuantities": [
        "lots": [
            "quantity": 1,
            "serialNumbers": "B8AB2026100011680"
        "carrier": null,
        "skuId": "RVR-BBA-510-B",
        "status": "SHIP_COMPLETE",
        "skuID": "RVR-BBA-510-B",
        "quantity": 1
    "packages": [
        "id": "22973",
        "trackingNumber": "1Z3A92R80302170304",
        "trackingUrl": "https://wwwapps.anc.com/etracking/tracking.cgi?tracknum=1Z3A92R80302170304",
        "status": "SHIPPED",
        "carrierName": "UPS",
        "height": 4,
        "width": 3,
        "length": 2,
        "weight": 3.06,
        "contents": [
            "sku": "RVR-BBA-510-B",
            "quantity": 1,
            "serialNumbers": [
              "B8AB2026100011680"
        "proofOfDelivery": "No",
        "carrierAccountNumber": "3A92R8",
        "serviceLevel": "UPS_GND",
        "merchantManaged": "W2G_MANAGED"
    "customerOrderType": "ECOMMERCE",
    "orderId": "SO52",
    "orderDate": "2025-10-21T19:36:14.000Z",
    "shippingSpeed": "ECONOMY"
@nuriensing you have any ideas here since you were just working on partial fulfillments?
The problem here is with you trying to fulfil a KIT item.
Instead, each kit component must be explicitly fulfilled, with correct subrecord inventory assignment, serial numbers, and component-level quantities.
For serialized kit components: You must fulfill at the component level, not the kit line
SO line (parent) — not fulfillable
SO line (component A) — fulfillable
SO line (component B) — fulfillable
example payload:
    "components": [
            "item": "COMP-001",
            "quantity": 1,
            "serialNumbers": [
                "B8AB2026100011680"
Hey @Ovina_Peiris ,
The Warehouse is only sending us the Item SKU - Component Level.
We don’t know if it is a Component of an Kit / Normal Serialized Inventory Item.
If possible can you please share the Mappings here.
Remove all dynamic fields and replace the lines entirely.
For now, only include the required fields so you can test.
Make sure the mapping with your skuid is set as a key-value pair and that the field exists on your sales order. That should be enough.
If it still errors, share the full request and the error message.
