Shopify Kits & Bundle Fulfillment
Hi everyone,
I have a flow setup to fulfill orders on Shopify. The issue I'm facing is fulfilling kits & bundles. The error message I'm receiving from kits & bundles is "{"errors":["Fulfillment payloads fulfillment order line items must contain unique line item ids"]}" All other items are being fulfilled. Any ideas to resolve this issue?
@shadnerjoseph on the saved search for your item fulfillments, are you getting the kit member items on your results along with the kit item itself?
Hi Tyler,
I am facing the same issue {"errors":["Fulfillment payloads fulfillment order line items must contain unique line item ids"]}" while fulfilling the kit items. In NetSuite, only the component items are fulfilled without the kit parent by adding the Etail Order line ID value to the kit components. Since all the component items have the same eTail order line Id, the saved search is picking all the kit components which is causing the error. How do we fix this? Please advise.
@shadnerjoseph @sravaninuagesync you would need to filter out the component items from your saved search results. One easy way to do this is to populate the eTail Order Line Id field on the sales order because this will only carry over to the kit item and other primary items on the IF, not member items.
