If you are unable to trigger NetSuite order to Salesforce order realtime flow in a v2 flow, add skipUpdateIfSfIdMatch:true attribute after the Salesforce ID field under Plugins array to the respective Celigo Realtime Export Flow record In NetSuite account configuration.
Note: Migrate your SF_NS V2 to SF_NS IO as soon as possible, as the services to SF-NS v2 will no longer be supported.
