I am trying to add what I thought would be a simple mapping to an existing flow to take the contents of a multi-select picklist from NetSuite and push them into a multi select picklist on Salesforce. I created the SF field myself and it has full read/write access.
An excerpt from the payload exported from NetSuite looks like this:
"baserecordtype": "promotioncode",
"duration-multi”: [
"internalid": "1", "name": "Monthly"
"internalid": "2", "name": "Annually"
"internalid": "3", "name": "Semi Annually"
"saleschannels": "ALL",
"audience": "EVERYONE",
I read on this doc that multiselect requires a special format to convert between NetSuite and Salesforce but I have tried this and the values are not mapped:
I have also tried using an #each as the values are in a collection but with no success.
And a straight {{duration-multi.name}} mapping does not work either.
Has anyone successfully mapped from MNS multi select to DSF multiselect?
