I was working with NetSuite item to Magento Product Add/Update flow in which when I added a check box field "non-discountable" in the mapping and running the flow an error is raised as shown below.
Mapping is done as shown below.
Since I have unchecked the corresponding checkbox in NetSuite, "5" is hardcoded as it is the value required to set the same field in Magento as 'No'. As per the error message I have already checked in Magento and run the mentioned Attribute Set Add Integration flow. Still the error is not getting resolved. Kindly suggest solution in an urgent basis.
