How do I use handlebars syntax to convert a string of numbers into a number?
Thanks for posting this to the community, @gilquerubin. I’m checking with our experts. In the meantime, check out the following resources:
Hi @gilquerubin,
Can you provide sample data of what you're trying to achieve?
You can try giving it in the following format:
If you want to use mappings then there's an option to provide "Data type" as a Number.
Hope it helps!
Thank you!
Hi @gilquerubin,
Did you find above solution helpful, or do you need any further assistance? Let us know.
Thank you!
