FAQ: How do I remove leading zeroes from field values with a handlebars expression?
Question: I have an ID field with values that have zeros prepended to the ID number. For example:
"id" : "0000000451"
Is there a handlebars expression that will remove the leading zeros while preserving the actual values?
Answer: Yes, you can use the following regexReplace handlebars expression:
{{regexReplace id "" "^0+" "g"}}
For more information on regexReplace, see Handlebars helper reference.
