Stop Conversion of '=' for next Page Trigger
In the export step at the beginning of the flow I'm building I need to specify that the Source uses Pagination by updating the Request Body. So I use 'Custom Request Body' in the Pagination Tab and fill it with the necessary information.
The Error now comes from the Response body having a '=' character for the next page which is autoconverted by Celigo to '=' which the Source can't parse and throws an Error.
How can I prevent Celigo from converting the special character or convert it back to a '=' before sending out the next page request?
Hello @janmaltebehrens,
I have moved your post to the Troubleshoot custom flows section for more visibility. Thanks!
Can you share screenshots of your export so we can see exactly where the characters are being converted? Can you also share a screenshot of your connection so we can see the media type being used? Be sure to mask any sensitive fields that you don't want to show publicly.
