Export Errors from Flow
Hey Celigo Community!
We have a custom flow with Orderful, and we get error in validation responses back from them that go into the native celigo error que. We are currently receiving a high volume of errors, and the only way to know what record they are for is to look at each on individually and get it from the payload. I'd like to see about exporting the error message from the error log, along with a couple of fields from the payload, so that I can send that export to a stakeholder, either to a google doc or csv export.
Has anyone tackled this?
Hello @michaelpilgrim,
I'm moving this post to our Troubleshoot section for more visibility. Thanks!
@michaelpilgrim896 You can explore multiple ways to achieve it:
  • Refer section "Send errors to an integrator.io listener (custom script)" on link
  • Generate a flow event report link
  • Get a list of errors link
