For a long time Celigo only supported publishing products to sales channels (Shopify Product Scopes field in NS), but a little while ago that was updated to handle when channels are removed as well.
Example:
Netsuite Shopify Product Scopes are "Online Store" and "Shop". "Shop" is removed from the list. On the next sync, Celigo would unpublish the product from the "Shop" channel in Shopify.
This has worked well since it was implemented until now.
We just realized that it is no longer removing channels when they are removed in Netsuite. I tested this and confirmed it would not remove a channel. Confimred that documentation still says that it should remove the channel. Debugged with Ora which also referenced documentation supporting my expected behavior as well as looked at logs and my flow data to determine that yes something is not working. I used that information from Ora to submit a support ticket.
Unfortunately so far the support ticket has not been the most helpful, which is why I am posting here.
Has anyone else had this feature stop working for them?
Could this be a bug related to the recent update to handle variant publishing to channels?
Hi @craigscott are you enabling the setting "Sync published scope from NetSuite to Shopify" under product.
Can you please share the support ticket number so that we can verify the setups from our end.
@nileshkumar overnight it started working for some reason, I am not sure why. I have products that last evening around 5pm Eastern had their product visibility scopes changed and should have updated in Shopify but did not. This morning when I came in I ran some tests and things were working as I would expect. It seems like an update to something was made to get it working, but support is telling me that is not the case. Regardless, it seems to be working today.
Unrelated to this issue we did discover that many of our variants online were getting unpublished from channels starting two days ago. I imagine that is when the variant publishing update in the October release notes went live?
We never managed the product visibility fields in Netsuite on the child product level because it was never anything that could sync to Shopify. So those fieids were a bit out of sorts when this Celigo update went live and it was a bit frustrating.
I think having a 'sync published scopes' setting for parents and for children would be helpful, rather than an all or nothing setting as it is now. We were not planning to manage published scopes on the child level in netsuite but now we have to update scripts and workflows to make sure it is all kept in sync.
@craigscott Glad to hear it’s working now. About the variants being unpublished: yes, that’s because of the variant-level publishing update in the October release. Shopify now supports publishing to sales channels per variant, and the integration now uses whatever sales channels are set on each child item in NetSuite.
A variant that doesn’t have a sales channel in its Shopify Product Scopes field gets unpublished from that channel, even if the parent has it.
Our recommendation: rather than reworking your scripts and workflows, select every sales channel you use on all child items, and keep managing visibility at the parent level. For example, if you sell through Online Store and POS:
Child items: select both Online Store and POS on every child item.
Parent item: turn a channel on or off here. Adding it publishes all variants to that channel, and removing it unpublishes all of them.
On matrix items, NetSuite copies the parent’s channel values to the child items when you create the item. When you later edit the parent, NetSuite asks whether to apply the change to the child items. Choose yes so the variants stay in sync.
We’d rather not go back to the earlier parent-only behavior, because variant-level publishing is a new Shopify capability. The setup above lets you keep controlling visibility from the parent.
