Scoping Problem with Integration tile custom settings
Hi Everyone,
I created an integration level setting to store the bucked ID for imports and exports using amazon S3. I then put this handlebar expression into the Bucket Name filed on the imports and exports. {{settings.integration.S3OutBucket}}
That expression works fine on exports but on imports it's returning null.
In AFE it works perfectly in both cases. When the flow runs, it's returning null.
This scoping still confuses me.
Thanks!!
Hi @davidgollom -
Thanks for posting this. We think our Support team should look into it, so I've created a ticket: #95813.
- Kate
I am having similar issues , even though i have select afe2 it seem to be running in afe1 .... so now i get nulls
Hi Everyone,
Currently there is bug on the S3 imports due to which the custom settings are not working as expected for the fields of S3 import. We would request you to hard-code the strings for the S3 import fields for now.
Thanks.
