SAP Connetors - Support for IDOC, BAPI and RFC
Hi,
Does celigo support (have pre-built connectors) for IDOC , BAPI and RFC integration. I could not find reference in any documentation provided. I could only find Webservices/Odata based integration guidance. Please advise.
Thanks,
Divya
Hi @divyanavakumar,
I'm moving this post to our main community forum, so that we can get you an answer more quickly. You can reach it at the same URL. Thanks!
Hi @divyanavakumar
Unfortunately, at this time, Celigo does not yet have prebuilt connectors for IDOC, BAPI or RFC. That said, there may be alternatives that can be used instead.
What is the use-case you have in mind/are working on?
Kind Regards,
Adel
