Hi Team
Thanks for adding MCP support, want to confirm if we can have Celigo MCP that covers most of apps, APIs.
Thanks
Hi Team
Thanks
Hi @idrisstalainteoulili ... Any connector can be included inside an API via API Builder and then exposed as an MCP Tool.
Does that answer the question you were asking?
Hi, Thanks for your answer , i want MCP that i can connect to any app and be able to create, update, patch, delete all celigo components including connections, exports, imports, flows….
Thanks
Ah, gotcha. It is a roadmap item for us to have an MCP Server the for the platform APIs. In the meantime, you could follow the pattern I described above for those.
If you don't mind sharing, what's the use case you are looking to satisfy with this feature? I'm wondering where you would be connecting from, and what sort of requests would be sent.
