Salesforce Fatal Error
I encountered the following error 'Composite Operation failed due to the following error(s) Required fields are missing: [Name, StageName] for Opportunity[0]' in the flow named 'NetSuite Sales Order to Salesforce Opportunity Add/Update'. While the flow works for most orders, it generates the mentioned error for some orders. Is there a solution to rectify this error?
Hello @azizayoujil
Thank you for your post. We will get back to you shortly with the required information.
Thank you for your response
Hello @azizayoujil,
Can you please confirm if the failing Opportunities have a Stage assigned and if that stage is the standard value as defined in the mappings?
I have assigned stageName for opportunities both statically and dynamically. However, the problem is that some opportunities are updated with the same criteria.
Can you confirm the successfully synced opportunities have the assigned stageName?
@@sushilpatil-sushil-patil" rel="nofollow noreferrer">sushil patil
I'm totally sure they have Name and StageName everything is correct but they still failing.
@azizayoujil can you create a support ticket for us to analyze this further?
thanks!
@sushilpatil-sushil-patil" rel="nofollow noreferrer">sushil patil thanks for your support.
I had already submitted a ticket.
