I am not able to run reports. Is this something I have to add to my account?
Hi @barbdowney After you select the integration, you can then choose the flow...
Thanks
[Moved this to our main troubleshooting area]
@barbdowney You should see integrations for which your id has access. I suggest that you submit a support ticket to look into this question.
Thanks
