We need to do an employee integration from a cloud-based (hosted) system to the QuickBooks desktop through Celigo.
Is it possible to connect to the desktop version?
Hi Tharaka, Unfortunately, Celigo cannot connect directly to a desktop version of QB. There are some third party apps that allow you to expose Rest API endpoints on your QBDT instance; however we can't recommend any specific one.
Thanks for the reply, Joe.
Is it possible to connect Celigo and third-party apps that allow us to expose Rest API endpoints on our QBDT instance?
Yes, if the third-party app exposes a standard Rest-API endpoint with any level authentication, you can use Celigo's Universal HTTPs connector to pull in data.
Thanks, Joe.
