Quickbook Banking Rules is not listed in Celigo Supported API. Is there a way to export that information using Celigo?
https://docs.celigo.com/hc/en-us/articles/17633431506075-Supported-QuickBooks-APIs
Hi @thaodinh,
I've moved your question to the Troubleshoot custom flows section, as it seems to be more about Celigo's ability to export data from an API than the Celigo API Management feature. Let me know if I'm wrong, and I'll move it back!
Thanks!
Hi Thao,
It looks like Quickbooks itself does not offer the banking rules via API. Celigo can support API's that are not listed in the UI based drop downs on the Quickbooks connector by switching to form view (see screenshot). This would allow you to put in the path for another API call. But those API's have to be available from Quickbooks.
