Hello All,
We are encountering an issue where the count of partially applied payments is higher in our settlement records.
Could you please advise how we can resolve this and process the partially applied payments so that we can complete the settlement?
Hi Swapnil,
Thank you for reaching out.
There can be several reasons why invoices are partially paid. Some common causes include a mismatch with the paid amount, the settlement being imported using a flat file that is not the V2 format, or taxes not being excluded when Amazon is remitting the taxes.
I would recommend comparing the invoice with the payment record and the settlement transaction order that was created to identify any discrepancies. Additionally, it would be helpful to review the Flat File V2 and verify whether the payment details are complete there, as it is possible that Amazon may not have included all the necessary information in the file. Lastly if you ever uploaded the flat file V2 using data loader, please check the settlement transaction order if the line level appears completely imported.
Hope this helps.
Hi, if the cause of partially applied payments have been fixed, how do we resolved the partially applied count and remove the variance?
Hi Hessed,
If the fix was applied directly to the payment, a manual adjustment would be the best approach, since the flow was not responsible for the correction.
If the correction was made on the invoice and you plan to resolve the partially applied payment using the flow, you will first need to delete the existing payment record. Once deleted, please uncheck the “Exported to IO” field on the settlement transaction and set it to "New” status, then rerun the payment flow to recreate and apply it correctly.
Regarding the variance:
- If you follow the second approach above, you will also need to delete the existing JE. Unchecking the “Celigo Amazon Settlement Exported” field in the settlement summary will allow the system to recreate the journal entry (JE), as the flow can only create new JE records and cannot update existing ones.
- If the payment was manually corrected but the settlement transaction was not updated, we recommend making a manual adjustment directly to the JE record.
Please note that the created JE is based on the settlement summary. The settlement summary update runs automatically after the payment and refund flows are completed. Therefore, correcting the settlement transaction by rerunning the payment flow should trigger the update, allowing you to recreate the JE properly.
