The last two settlements that we ran, we forgot to run the Journal Entry Flow. Is there any way we can go back and run these flows against the settlements that were already imported? Thank you.
Hi,
Journal entry flow is a once export flow. We use the field "CELIGO AMAZON SETTLEMENT EXPORTED" present on Settlement Summary record to determine whether this is already exported or not. As long as it's unchecked, the next time you run the flow those old ones will also be picked up.
