It was difficult to come up with a title that concisely described the issue. I'm posting this here as an FYI to the community and a bug report to Celigo. Reporting bugs via support is too difficult, but I want to get the bugs logged so hopefully this is an effective method.
Symptom: Input preview for Input Mapping or script editor has no records. You check the previous step Transform, Output mapping, Pre Save Page script - they all have valid input and output previews. The following Import step?.... nothing.
The scenario:
- Export step has a Pre Save Page script works with the options.files array, copies filenames and asserts there is precisely 1 file in the array. This works perfectly fine when editing the script and previewing it.
- The following Import step has no record data in it's Input previews
- Disabling the Pre Save Page script causes data to appear in the Import previews again
Logging the serialized options parameter in the Pre Save Page shows what the problem is; there's no files[] property on the options object when the script is evaluated in the flow. Again, this is hard to explain. I'm sure if I RUN the flow, it will be fine, but when I'm editing the flow and IO evaluates the flow to generate the Input previews, it is omitting the file[] array. This in turn causes the scrip to throw an error and downstream Input previews are blank.
The only solution I can find is to code the Pre Save Page script to expect a missing files[] array. This isn't right, I don't like writing weak code with undefined behavior like this, but what choice do I have?
Expected behavior: Pre Save Page is called with the same options object during runtime/editing as it gets when editing the script.
The script is very simple!
function onPreSavePage (options) {
  //  Copy the export filename to the record so it's part of the retry data and maybe we'll
  //  save on the record in NetSuite in case we need to investiage what happened.
  options.data.forEach(record => {
    //  There should always be a filename, if there isn't we want to throw because that's completely unexpected
    if (options.files.length !== 1) {
      throw `Expected exactly 1 file record but found ${options.files.length}`
    record._ediFilename = options.files[0].fileMeta.fileName
  return {
    data: options.data,
    errors: options.errors,
    abort: false,
    newErrorsAndRetryData: []
