I have the following as output from an HTTPS API. I'm trying to use it to import items into Netsuite. I have an Input Hook that removes the "first record" which is the column headers. This allows me to get 1 item in but it only does 1 and there isn't an error. Looking for ideas on what I need to change to have all the exported records to be processed.
Here's the export object, I'm getting from the API.
"page_of_records": [
"record": {
"masterVariables": {},
"data": [
"Product ID",
"Description",
"Std packing",
"Duration",
"Caliber",
"Status",
"Category",
"Hazardous\nmaterial",
"Average cost",
"Product Url"
"518245",
"3\" Finale to be Tied for Show ",
1,
null,
"3\"",
"Active",
"3 Inch Finale",
null,
null,
"/zambellifireworks/api/product/518245"
"NEO3TESTPRODUCT",
"This is my description",
null,
null,
null,
"Active",
"4 Inch",
null,
null,
"/zambellifireworks/api/product/NEO3TESTPRODUCT"
"PatDummy1",
"Test Test Test",
72,
3,
"3\"",
"Active",
"3 Inch",
"UN0335",
null,
"/zambellifireworks/api/product/PatDummy1"
