Object Deletion Using HandleBars?
Hi Everyone,
I am using Import Template to change the data format.
In my Use case I want to remove an object from data format.
Is it possible to delete the that Object using handlebar expression.
@anekporwal842 thanks for your post! Could you provide an example that would help us better understand the use case?
(I've moved this post from "Welcome to our community" to "Troubleshoot custom flows" for visibility.)
