Handlebars in Mapper Array
Trying to use a handlebar in Mapper 2.0 I get the following error:
Mapper 2.0: You can only use a valid JSONPath expression or hard-coded value for destination field(s): ids
I only get this when I map to a [number] or [string].
Handlebar expressions are only supported for string, boolean, and number destination data types.
In the past, yes, that made sense because you couldn't get a usable array value out of handlebars, but now you have all these new handlebars that return arrays:
{{arrayify}}, {{pluck}}, {{unique}}, {{after}}, {{before}}
You wouldn't want these to go to waste, now, would you? :slight_smile:
Well I didn't say we weren't working to support it, just that we don't currently :slight_smile:
Thanks! I guess it's just a pre-map script in the meantime.
