NetSuite OAuth2.0
I’ve been looking for documentation that could help me set up a connection to NetSuite using OAuth 2.0 Machine-to-Machine, but I haven’t been able to find any. I already have all the OAuth 2.0 information ready with me; I’m just not sure what information should be entered in the integrator.io connection setup.
Is it even possible?
I've been attempting to do this and it seems feasible, but I've been unsuccessful. I'll check internally to see what we're missing.
With the help of our awesome engineer @yashmodi, we were able to get NetSuite OAuth 2.0 Client Credentials (Machine-to-Machine) working with a Celigo HTTP connection. Below is the full setup.
Out of curiosity, what is driving you to use OAuth 2.0 with NetSuite as opposed to OAuth 1.0 or using our native NetSuite connector?
1) NetSuite setup
A) Create an Integration record
In NetSuite, create a new integration record:
Setup → Integration → Manage Integrations → New
  • Enable Client Credentials (Machine To Machine) Grant
  • Enable the scopes you will need (make note of which ones)
  • Save the record, then copy and save the Client ID
    • For M2M, you generally do not need the Client Secret in Celigo.
B) Generate a public/private key pair
Generate a key pair and certificate. NetSuite doc:
https://docs.oracle.com/en/cloud/saas/netsuite/ns-online-help/subsect_162755332391.html
Example command (this is what I used):
openssl req -new -x509 -newkey ec -pkeyopt ec_paramgen_curve:prime256v1 -pkeyopt ec_param_enc:named_curve -nodes -days 365 -out public.pem -keyout private.pem
C) Create an OAuth 2.0 M2M setup record
Go to:
Setup → Integrations → OAuth 2.0 Client Credentials (M2M) Setup → Create New
  • Select your Entity
  • Select the Role
  • Select the Application/Integration you created earlier
  • Upload the public certificate (public.pem)
  • Save and copy the Certificate ID (you will need it in Celigo)
2) Celigo setup (HTTP connection)
A) Create the HTTP connection
Create a new HTTP connection in Celigo:
  • Base URI
    https://<accountid>.suitetalk.api.netsuite.com
  • Auth type: OAuth 2.0
  • Create a new iClient
  • Grant type: Client Credentials
  • Enable Use JWT
  • Signature method: use the one matching your cert (mine was ES256)
  • Paste your private key contents (private.pem) into the private key field
B) JWT payload
Use the following JWT payload (update <accountid> and scope to match what you enabled on the Integration record):
  "iss": "{{{iClient.oauth2.encrypted.clientId}}}",
  "aud": "https://<accountid>.suitetalk.api.netsuite.com/services/rest/auth/oauth2/v1/token",
  "iat": {{{dateFormat 'X' (timestamp) 'YYYY-MM-DDTHH:mm:ss.SSS[Z]'}}},
  "exp": {{{dateFormat 'X' (dateAdd (timestamp) '2700000' 'UTC') 'YYYY-MM-DDTHH:mm:ss.SSS[Z]'}}},
  "scope": "rest_webservices,restlets"
Notes:
  • Make sure the scope values here are enabled on the NetSuite integration record.
  • The exp above is set to about 45 minutes after iat (2700000 ms).
C) JWT headers
  "typ": "JWT",
  "alg": "ES256",
  "kid": "{{{iClient.oauth2.encrypted.certificateId}}}"
  • alg must match the signature method you chose (for example, ES256).
D) Token endpoint
Access token URL:
E) OAuth 2.0 overrides
Under OAuth 2.0 overrides:
Headers
content-type: application/x-www-form-urlencoded
Body
  "grant_type": "client_credentials",
  "client_assertion_type": "urn:ietf:params:oauth:client-assertion-type:jwt-bearer",
  "client_assertion": "{{{iClient.jwt.token}}}"
F) Configure token auth
  • Send token via: HTTP header
  • Header name: Authorization
  • Header scheme: Bearer
G) Non-standard API response patterns
  • Override HTTP status code for auth errors: 400
H) Advanced → Encrypted fields
In Advanced → Encrypted fields, add:
  "certificateId": "",
  "clientId": ""
…and populate those values with:
  • certificateId = the NetSuite Certificate ID from the M2M setup record
  • clientId = the NetSuite Integration record Client ID
3) Test the connection
In the connection test:
  • HTTP method: GET
  • Relative URI:
    /services/rest/record/v1/metadata-catalog
Thanks Tyler, this is perfect, I will try this and let you know what is the result.
It’s just a personal preference, I just don’t want to do the flow(me being lazy :laughing: )
@tylerlamparter Works perfectly. Thanks for the detailed steps.
Hi @tylerlamparter, Not sure if this is the right place to initiate this discussion, happy to create to a separate thread if necessary. I have tried configuring an OAuth 2.0 JWT connection for NetSuite, however I am getting a 401 error when I make the final API call, I see that a token is being sent in the header though.
I followed all the steps above, screenshots below, I see a different error message in the parsed output. Any help would be greatly appreciated, thanks.
I'd go through the setup again to double/triple confirm everything is setup the same. After that, maybe you could share screenshots of your setup? Or you could join office hours tomorrow.
thanks for the reply, will try and join office hours, it would be 3AM here in Melbourne.
Were you able to figure this out? If not, I'd suggest reaching out to your account rep for an "Ask an expert" session so someone can help you out one on one (for free!). Additionally, you could reach out to support.
Yes, finally it worked. I forgot to post an update here.
I entered clientId in a separate line. Like below:
"clientId": ""
However, both certificateId and clientId should be in the same line, next to each other :slight_smile:
like this (also in your screeshot above)
"certificateId": "", "clientId": ""
