Hello,
I'm having trouble mapping the landed cost field in NetSuite Item Receipt from integrator.io. These are fields in NetSuite I'm trying to map:
But in integrator.io I can't find the appropriate field for it and I also tried using the NetSuite assistant but I can't select that field so it can map it. How can I find which field in integrator.io corresponds to the landed cost field in NetSuite? Here is how my import is setup and the mapping as well:
@hristinabendeva615,
Sorry for the belated acknowledgement, but thank you for posting your challenge to the community. It looks like you are currently working with Celigo Support on a resolution. When that is complete, we would greatly appreciate you posting an update here.
Hi, has there been any status updates on resolution? We are facing the same issue with no resolve. Would love to know if this has been solved.
Hello @lysiconsulting-LYSI-Consulting" rel="nofollow noreferrer">LYSI Consulting,
We have found a solution to this problem:
1. Since my Role "Celigo integrator.io Full Access w/o 2FA [Locked]" was locked, I have replicated same Role and created new one from this Role.
2. In the new created Role I have enabled "ENABLE ESTIMATED LANDED COST" checkbox.
3. After that I have updated Account in NetSuite that have Administrator privilegies and grand access to the new created Role from step#2.
4. Create Access Token with updated Administrator user from step#3 with new created Role from step#2.
5. Create new NS Connection with generated Token ID and Token Secret from step#4.
6. In the mapping to NetSuite you need to map the "Landed Cost per Line" and "Items : Calculate Est. Landed Cost" fields with hardcoded value to "true"
