Hi,
Question about Netsuite/Sales Orders:
Is anyone setting fieldid: costestimatetypesuccessfully on item lines?
Example of what I am trying to do:
In this case Line ID is used as a key to find the existing line.
Error I get: invalid_key_or_ref
I have tried multiple combinations leading to the same error, namely:
- Mapping the field
Items : Cost Estimate Type (Name)using:
- "Item Defined Cost" (shown in pic), "ITEMDEFINED" (this id shows on the backend using netsuite field explorer), "4" (netsuite also stores a
costestimatetypearrayon the sales order record that has numeric keys)
- Mapping the field
Items : Cost Estimate Type (Internal ID).
- the same 3 options used to no avail;
All of these tests failed with the same error. Netsuite's own documentation points to using:
nlapiSetFieldValue('costestimatetype', 'PREFVENDORRATE'); with scripts.
Looking at the logs in celigo during my efforts:
r.setSublistText({"sublistId":"item","fieldId":"costestimatetype","line":0,"text":"Item Defined Cost"});
Seems like the io restlet's trying to perform the wrong method? Any ideas how to fix this? If this is a bug - any workarounds possible?
Thanks,
Marin
