Multi-field field map with child lookup
I have a results mapping where I need to combine values that have multiple locations 1 in the parent object and multiple in the child objects. For simplicity sake the object looks like this:
"id": "294726",
"tags": "black, orange",
"child_items": [
"id": "295544",
"tags": "red, blue"
"id": "295545",
"tags": "yellow, green"
"id": "295546",
"tags": "tall, pink"
I tried {{tags}}{{child_items[*].tags}} but that is throwing an error. How can I get the resultant field called tags to have "black, orange, red, blue, yellow, green, tall, pink"?
Hi @coreyhunt
We can achieve this use case using a script in postresponsehook. Add a script that traverses to all objects and you can push those values into an array or to another JSON object.
Thanks!
I was afraid that was the case. Thanks, I'll give that a try.
