More_than_one_match_found when updating a single custom record in NetSuite via Celigo
I’m trying to update one specific custom record in NetSuite via Celigo, but every lookup returns a more_than_one_match_found error, even though only one record exists.
1. Background
  • Custom record type: AFP
  • NetSuite record type (internal): customsale_afp
  • Goal: Update exactly one AFP record via Celigo
2. Problem with lookup criteria
In the Celigo lookup criteria for the AFP record:
  • Internal ID is not available in the dropdown list for this custom record type.
Workaround I tried:
  1. Temporarily change the record type to Transaction
  2. Add a lookup criterion using internalid
  3. Switch the record type back to AFP
3. Result when using Internal ID
Even when I use the exact internal ID of the AFP record, Celigo returns:
  "code": "more_than_one_match_found",
  "message": "A mapping error occurred. More than one match for \"[\"internalid\",\"is\",\"52719\"]\" for the record type \"customsale_afp\".",
  "source": "lookup"
This happens despite:
  • Only one AFP record existing with this internal ID
  • That record having only one line
4. Tried using a unique custom field instead
To rule out internal ID issues, I:
  • Added a custom body field (custbody_afp_id) to the AFP record
  • Populated only one AFP record with a unique value (1337)
  • Used that field as the lookup criterion
Result:
  "message": "A mapping error occurred. More than one match for \"[\"custbody_afp_id\",\"is\",\"1337\"]\" for the record type \"customsale_afp\".",
  "source": "lookup"
5. Additional things I tried
  • Different operators: is, any of, equal to
  • Adding mainline = T and mainline = F
  • Reducing the Celigo mapping to a single field update
  • Ensuring only one record in NetSuite has that value
None of these changed the result.
6. What confuses me
  • There is only one AFP record
  • That record has only one line
  • Both internal ID and a unique custom field still return “more than one match”
7. Possible clue
The customer on the AFP record is a child customer (sub-customer).
I’m not sure if this could affect the lookup behavior.
8. Question
Has anyone seen more_than_one_match_found:
  • On custom transaction records
  • When the lookup clearly targets a single record
  • Or related to child / parent customers
Any insight into what NetSuite or Celigo might be matching “multiple times” here would be appreciated.
What happens if you try the same criteria on a lookup as opposed to a lookup within an import?
This did the trick, thanks @tylerlamparter .
What I did was create a lookup and determine the exact criteria needed to return a single record. It turned out the lookup only worked with these specific conditions:
– Record type: Transaction criteria
– custbody_afp_id equal to 1337
– mainline is true
In the import step, I changed the record type from AFP (custom record) to Transaction so I could use the equal to operator and add the mainline condition. After that, I switched the record type back to AFP.
By the way, why can’t we use all fields or operators directly when working with a custom record, now you need to switch from record A to B in order to get the correct criteria in Celigo.
Can you share what field type custbody_afp_id is on the NetSuite custom record? Also, if you run a search in the NetSuite UI for that custom record, what operand options does it give you? I think we detect the field type and provide the appropriate operands, but there may be an issue here. Usually, equal to is only for number-type fields.
custbody_afp_id is an integer field so thats correct.
