I am getting this error. Can anyone help me?
"A mapping error occurred. Could not find a match for \"[[\"internalidnumber\",\"isempty\"],\"OR\",[\"custitem_celigo_sfio_sf_id\",\"is\",\"01t5j000003mFuGAAU\"]]\" for the record type \"item\"."
Hi Animesh,
It could be a chance when you don't have a Salesforce product id in NetSuite with (01t5j000003mFuGAAU) this Salesforce ID.
To fix this issue, two ways
1. We should sync your products between Salesforce and NetSuite to make this work.
2. If you go to the general setting, you will see "Product discovery", please try to set the unique field.
ex: In Salesforce you have a Product code with "PO112233" and in NetSuite, you have the same name with "PO112233" then you can set it from NetSuite as the "Name" field and from Salesforce you can set it as "Product Code" field.
