I have a Netsuite Lookup that looks for existing Customer Part Numbers based on the following additional criteria:
In the lookup One to Many is put to yes. With the path to many set to the line items in the JSON.
So I want to fetch all results on the combination of: "Customer Part Number" and "Customer". The results will be passed on to the next flow due to the following result mapping:
I tried the following scenarios with 3 line items:
Scenario 1:
Line item 1 has a customer part number that does not exist in Netsuite.
Line item 2 has a customer part number that already exists in Netsuite.
Line item 3 has a customer part number that already exists in Netsuite.
So lookup will be performed 3 times with the line items above. However both 3 times I will am getting an empty result:
"nsCustomerPartData": [],
"nsCustomerPartDataError": []
I actually excepted that line item 2 and 3 had results and only line item 1 was empty. This however is not the case.
Scenario 2:
Line item 1 has a customer part number that already exists in Netsuite.
Now I am getting results for every line item. For example line item 1 shows:
"id": "xxx",
"recordType": "xxx",
"Name": "xxx",
"Item": "xxx",
"Customer": "xxx",
"Subsidiary": "xxx",
"customer ID": "xxx",
"Date Created": "15/09/2022 13:35"
So it seems the problem is that the lookup results will be empty for all line items when there is no result for the first line item. Is this a bug?
