I'm a novice to Celigo and integrations. I need to create an integration process to download reports from Toast. While using the API seems like a solution, it requires partnership credentials from Toast. A colleague mentioned using FTP. Can Celigo export Toast reports via FTP? If so, how do I set this up?
Hi @thaodinh ,
Thank you for reaching out.
Have you tried downloading the files via Cyberduck or terminal as mentioned in this article?
If you are able to access the files, we can use the same credentials to create a connection/export in the Celigo platform.
Please let us know if you need more details.
Best Regards,
