Hello,
Has anyone ever come across a requirement to download a file from a URL and then upload it to an FTP server?
The FTP part is simple and can be done, the issue is i am not sure how to get Celigo to download the file from the URL, any suggestions?
Thanks,
Mike.
Out of curiosity -
Does the site in question provide an API (Rest/SOAP) that contains the path to the file that you're trying to download, or are you just trying to download a file of unknown type directly from a URL?
Hi Mike,
What application do you download a file from? If the endpoint has an API that points to the file, a generic connector such as REST or Http can be used to download a file from the api. For example, you can download Jira attachments from a url like: https://abcd.atlassian.net/secure/attachment/file_id/file_name
However, we identified a bug that causes issues with file download. The fix is planned for our July release.
Thanks
Hi Both,
@wadeshelton It is from NetSuite, so yes it has both RESTlets and SOAP APIs - I've never done a file transfer this way though maybe i should look into it a bit more.
@viliandyleonardo are you saying it is possible, but there is a bug at the moment? I'm just trying to find the easiest way to get around the limitation of sFTP only transfers from NetSuite. If it is possible could you give me a quick example? I can know the link before hand if thats of any use?
Thanks.
@alexanderlaporta Thank you for adding information. The issue I was referring to is applicable only if you create a generic connector out of REST or Http connector.
Could you please elaborate what integration you want to build? What does "get around the limitation of sFTP only transfers from NetSuite"?
We have an example of exporting a file out of NetSuite in the Marketplace. When you logged in your IO account, navigate to MarketPlace and find this template that shows you how to extract files out of NetSuite.
Thanks
