Several of the integrations in my celigo workspace have tags that help organize similarly named integrations:
I can edit these tags, but I can't figure out how to add new tags to the newly created integrations I have created.
The tags are only available for "Integration Apps" where we do not let users change the name of the integration. For the integrations that you build yourself, you can name them however you like, and there is no need to set a tag also.
Thanks Scott. If customers want to use the same naming convention as integration apps for consistency, then I think allowing custom integrations to also be able to add tags would be a useful feature.
I thought I had submitted this Idea in the marketplace, but I don't see a way for me to search for the ideas that I have suggested in https://integrator.io/productPortal
