HubSpot Deal Lookup Not Working
Looking for community assistance as I think this is a common enough setup that perhaps someone also has the same setup and can see if there's is configured differently.
I have a flow like so:
(1) Step 1 import HubSpot company data - also bring in the 'associated deals' parameter
(2) Step 2 lookup affiliated Hubspot deals.
Unfortunately, my step 2 is erroring out with a '404 not found' message when running.
Screenshot for step 1:
Step 1 sample data returned (with the deal data I am trying to get at identified in the red box):
Step 2 configuration:
It was recommended in office hours to set up step 2 as above. However, we didn't have time to run the flow in office hours, so I didn't realize it failed until after I left.
Any assistance would be so greatly appreciated! I have messed around with the 'path to many' part to no avail. Not sure if I am just missing something small somewhere. Perhaps my 'Deal Id' identifier of {{id}} is not fully correct? Really out of ideas!
Thanks for posting to the community, @arielbrowne! That's a good idea to try to get some more eyes on this from others with a similar HubSpot setup. Our customer support ninjas are actively working on your case too. When this is resolved please do post an update so others can benefit from your experience.
Hi @katelarson,
I've made some progress.
In step 2:
  • The first is that I removed the 'one to many' requirement. I don't think I need it for my purposes anyways
  • For 'Deal ID' I also used a slight work around. We have a field within the company object that I have placed the deal ID in. This won't necessarily work for everyone if they are pushing through multiple deals at the same time, but for our purposes, we are only pushing through the most recent deal. So I made a Hubspot workflow to push that deal ID to the company object
  • The last step I actually think was the cause of most of my problems. In step 2, you can configure your search parameters to bring in the required fields from the deal:
    Within the search parameters, I entered ‘id’ for ‘ID Property’ (because my deal unique identifier property is called ‘id’.
    When I do that, the whole thing breaks.
    So one problem down, but onto the next…
    Now when I try to map any of the deal properties into NetSuite, they don’t get imported into NetSuite, it’s just blank🥲
    I’ve brought my deal data into the results mapping for the lookup:
And I've mapped one of the deal properties into netsuite just to test it out, but unfortunately it doesn't work. I can map any of the Hubspot company properties to the NetSuite 'comments' but none of the deal ones:
Hey Ariel,
For your mapping into the Comments field, you'll need to use handlebars statements to create a single string out of your data.
I used our Dev Playground (available under Tools if you enable Developer Mode under My Account) to create the following:
So, here I'm looping through both levels of data to get to properties.pipeline and this ends up printing them out as a single string (in the bottom right).
The statement is: {{#each dealdata}}{{#each results}}{{properties.pipeline}}, {{/each}}{{/each}}
You should be able to just copy and paste that into the field where you currently have dealdata[*].results[*].properties.pipeline
Thanks,
-Lucian
Hi @lucianhymer,
Unfortunately it is still mapping a 'null' value despite in the debugging log showing that data existing with that deal. Here is what I have now tried to no avail (all map as null in the debugger):
  • {{#each dealdata}}{{#each results}}{{properties.pipeline}}, {{/each}}{{/each}}
  • This one was recommended by someone else: dealdata.0.results.0.properties.pipeline
  • {{properties.pipeline}}
  • {{dealdata.properties.pipeline}}
Any clue? I should note, that the actual mapping drop-down menu choice shows dealdata[*].results[*].properties.pipeline which is why I choose it originally.
I learned from customer support that the following handlebar statement resolved this issue:
{{getValue "dealdata[0].properties.dealname" "defaultValue"}}
