HTTP Request and HTTP Response are blank
I am using the HTTP connector to connect with MS Dynamics CRM/CE. I have successfully created an account record in CRM. I am trying to get back the GUID ID of the record created. My first question is why don’t I see anything under HTTP Request or HTTP Response when I do a Preview or Send on the Import window? Shouldn’t it show the request and response, at least on Send?
Hi,
Would you be able to share a few screenshots with more detail? Feel free to blur any sensitive information.
See the snips below. I clicked the Send > button, but nothing shows.
If you enable debug logs for the import in the top right, do they show up there?
Yes, I do see request and response data there. I am not having much luck making sense of it.
When I turn on debug logs, and then go back out and click Send, it says Success 1 page, 1 record.
However, when I go back into the debug log, I see gets on several records. My import is a
composite operation, so it does a GET to determine whether to do a POST/create or a PATCH/update.
I see several GETs in the log, and then one POST. According to the Send, it only processed 1 record!?
