Hi experts,
I have having a use case where I have to send the FTP files to NetSuite File Cabinet, but I am not able to write any files to the file cabinet.
Can anybody tell me how to send the file from FTP to NetSuite file cabinet?
Thanks,
Hi experts,
Thanks,
Thanks @bhushanrane for replying.
I tried the above approach and error popped up saying "The specified internal id is not allowed" . Below is the screenshot.
Not sure what is reason here, I tried giving different folder Ids still seeing the same error. Can you please tell me what could be the issue here?
Does the user/role on your connection have access write permissions on those folders?
I am in the process to attempt to do the same thing of transferring an file (any format) from FTP folder into NetSuite. I notice that Chirag was having issues.
There are any easy steps to accomplish this?
Thank you!
Hi @gabrieljarillosoto -
The recommendation from our Support team is to use the following quickstart template available in the Celigo Marketplace:
NetSuite - FTP template
Thanks,
Kate
I have downloaded the template and am trying to pull files from a folder in Netsuite onto an FTP folder. The temple is using a saved search to pull a folder with files in it. Is there anyway to have an example of a saved search that is accomplishing this? I've tried a couple but haven't been able recreate one that works with this sample. Thanks!
Tim,
Thanks for posting to the community. I'm checking with our experts.
Anitha
Hi @timtrimble
NetSuite saved search should be created on a Folder and it should return File : Internal Id and File : Name of the files to be exported from the target folder.
Please refer to screenshots below.
Kindly notice the custom label file_id and file_name, use the same label on your saved search as they are used in subsequent steps. The file_id is used to extract the file and the file_name is used while importing the files in FTP, you will find them under File Fields ... join option in saved search.
NetSuite Folder Search filter example:
Hello,
Alternatively, The Doc here, can help to have the Saved search installed. Feel free to use the bundle for the quick setup :).
Thanks!
Wow! Thanks so much for the rapid response. I installed the bundle and now I'm cooking. Thanks again, very much appreciated.
Was there a solution to the original post from @bhushanrane-Bhushan-Rane" rel="nofollow noreferrer">Bhushan Rane? Having the same “The specified internal id is not allowed” error and permission are set to full as well.
