How to Debug Your Celigo Scripts
Debugging your Celigo scripts effectively can be done using an integrated development environment (IDE) like Visual Studio Code (VSCode). Instead of relying solely on console.log statements, a real debugger provides more powerful tools for troubleshooting your code. This guide will show you how to set up and use the debugger in VSCode to debug a Celigo Integrator script.
Setting Up the Debugger in VSCode
  1. Open VSCode and Set Up a Workspace: Make sure you have VSCode installed on your computer. Open VSCode and create or open your workspace.
  2. Create a New File: Create a new JavaScript file, for example, test.js, where you will write and debug your script.
  3. Add Your Code: In the new file, add the following components:
    • The Function Input (JSON Object): Define the input object for your function. In code example: options.
    • The Function: Write the function you want to debug. In code example: function transform(options).
    • The Function Call: Call the function to execute it. In code example: transform(options);
    Here's an example script:
    const options = {
      record: {
        "thisIsATest": "test"
    function transform(options) {
    options.record.name = "Nuri";
    console.log(options.record.thisIsATest);
    console.log(options.record.name);
    return options.record;
    transform(options);
  4. Set a Breakpoint: To set a breakpoint, click in the gutter next to the line number where you want the execution to pause. A red dot will appear indicating the breakpoint.
  1. Run the Debugger:
    • Click on the debug icon on the left sidebar.
    • Make sure your code file (for example test.js is open).
    • Select "Run and Debug" to start the debugging session.
  2. When prompted to select an environment, choose "Node.js" because Celigo scripts typically run in a Node.js environment.
Installing Node.js: If you haven't installed Node.js yet, follow these steps:
  • Go to the Node.js website.
  • Download the installer for your operating system.
  • Run the installer and follow the prompts to complete the installation.
Node.js is essential for running JavaScript code outside of a browser, which is why it is needed for debugging Celigo scripts.
  1. Navigating the Debugger:
    • Control Panel: Use the control panel at the top to step through the code (Step Over, Step Into, Step Out).
    • Variables Pane: On the left side, you can inspect variables and their values.
    • Hover to Inspect: Hover over variables in the code to see their current values.
  2. Inspecting Variables: As you step through the code, you can inspect the state of your variables. This helps you understand how data is being manipulated within your function.
  1. Continue Execution: After inspecting and making necessary changes, you can continue the execution of your script by clicking the play button. And you can stop it anytime using the stop button.
  2. Debug Console: In the Debug Console window below you can see the console.logs.
By following these steps, you can efficiently debug your Celigo scripts using VSCode. This method provides a more comprehensive view of your code's behavior, allowing you to troubleshoot and fix issues more effectively.
I hope you find this guide helpful. Happy debugging!
@nuriensing thanks for sharing!
Great Post Nuri ! Thank you for sharing !
Thank you all!
Using this method, how do you see the output?
Hi @nuriensing! Would love to hear your thoughts on this one—mind jumping in and sharing your insights? Thanks a bunch! :raising_hands:
Hi,
@jackharris
After clicking Run and Debug, switch to the Debug subtab.
That’s where you’ll find your actual debug logs.
You are now at the Output tab.
Unless there is a reason you want to have it via the Output tab.
But then you need to or install an extension or do some config settings.
However I would recommend using the Debug tab.
