I am trying to import salesorderitems from SF.
Then i am trying to create a credit and debit line for every order line item using a transformation.
I am using a transformation using javascript shown below but it doesnt seem to work.
This is how orderlines looks like for a salesorder
"page_of_records": [
"record": {
"attributes": {
"type": "s_c__Payment__c",
"url": "/services/data/v61.0/sobjects/s_c__Payment__c/a10V100000Kqx3iIAB"
"Id": "a10V100000Kqx3iIAB",
"Name": "Payment-1048492",
"s_c__Order_Id__c": "801V100000nR3fEIAS",
"Order_Number__c": "01825890",
"Deposit_Account__c": "10302",
"Cash_Sale__c": true,
"Customer_Deposit__c": true,
"s_c__Amount__c": 159.75,
"Order_Paid_In_Full__c": true,
"Batch_ID__c": "1055493750"
"record": {
"attributes": {
"url": "/services/data/v61.0/sobjects/s_c__Payment__c/a10V100000Kqx3jIAB"
"Id": "a10V100000Kqx3jIAB",
"Name": "Payment-1048493",
"s_c__Amount__c": 479.25,
function transform (options) {
// Normalize: transform may get the full page (array) or a single record
var input = options.record;
var creditRecords = Array.isArray(input) ? input : [input];
// Unwrap if fields are nested under a "record" property
creditRecords = creditRecords.map(function (r) {
return (r && r.record) ? r.record : r;
var DEBIT_ACCT = '703'; // hardcoded debit-side account
var CREDIT_ACCT = '539';
var lines = [];
var ex = '';
creditRecords.forEach(function (rec) {
var amount = rec.TotalPrice;
ex = rec.OrderId;
// Shared dimensions for both sides of the pair
var department = rec.Department__c; // confirm -> internalId
var klass = rec.Service_Line__c; // confirm -> internalId
var location = rec.Netsuite_Location_Id__c;
// Credit line
lines.push({
linetype:'credit',
credit: amount,
debit: 0,
account:CREDIT_ACCT,
memo: 'Credit Line',
department: department,
class: klass,
revrecstartdate: rec.Rev_Rec_Start_Date__c,
revrecenddate: rec.Rev_Rec_End_Date__c,
revrecrulename:"Rev Start/End Date"
// Debit line (mirror)
lines.push({
linetype:'debit',
debit: amount,
credit:0,
account: DEBIT_ACCT,
memo: 'Debit Line',
class: klass,
revrecenddate: '',
revrecstartdate: '',
revrecrulename:''
// Build the JE header + nested lines
return {
externalId: ex, // TBD - derive from Order or a sequence
subsidiary: '3',
currency: '1',
memo: 'Dummy JE for testing', // TBD
approved: false,
customform: '221',
lines: lines
// tranDate / postingPeriod omitted - you said they're auto-populated.
// Add them here if you'd rather set them explicitly.
The transformer i am using is abv and the NS mappings are below
z
I keep getting errors from NS below which makes me think that the transformer is not working
How can this be corrected ??
