From netsuite to celigo to extensiv 3pl
Good afternoon everyone,
I'm trying to understand how to make the subject's integration.
I would appreciate an overview of how to make this work.
Thank you,
Hi Dylan,
Celigo already has a NetSuite–Extensiv quickstart template, so that would be the first place I’d look instead of building everything from scratch.
It includes common flows such as sending items, sales orders and purchase orders from NetSuite to Extensiv, and bringing shipment confirmations, inventory adjustments and receipts back into NetSuite.
The exact setup will depend on which Extensiv product you’re using and what you want each system to control. Before configuring the flows, I’d confirm the system of record for items, inventory, orders and fulfilments. It’s also important to align item identifiers, locations, subsidiaries and order references between both systems.
Are you using Extensiv 3PL Warehouse Manager, formerly 3PL Central? Also, which records do you need to send in each direction? Once that is clear, the appropriate standard flows and any required customizations can be identified.
