A major deficit from a developer's perspective is the lack of customizing available in the integrator app. I saw that we have now the ability to clone, and just was able to accomplish that. But is seems that the cloned version is just as locked down as the original. I remember a discussion a ways back where the thought was that though Celigo didn't want customers changing the integrator app itself, making a clone was seen as an way to allow such customization without Celigo feeling the need to deal with problems. Or am I missing something. I have the Netsuite/Salesforce app, but in the clone for isntance, I still cannot make transformation or create/edit and javascript hooks.
You are right, The integration Apps can be customized by leveraging settings, mapping rules and filters but to add transformations/javascript hooks, you would have to use the Salesforce - NetSuite Templates in the Marketplace as those components cannot be applied to managed flows in the Integration Apps. Note: The templates may not cover all the functionality in the Integration App as IAs are managed and continuously updated. Cloning feature creates another instance of the Integration App (i.e. to copy changes b/w Production & Sandbox) and won't help w/ your use case as you also discovered.
I'm curious to know your use case further to apply transformations/hooks to see if there are other ways we can suggest to help you here.
