Q. I have a flow set to start overnight at 1 a.m. When I look at the dashboard the next day, I notice that it was often executed a few minutes later, sometimes even 10 or 15 minutes after the hour. What might be causing the delay? Is there anything I might need to fix?
A. Whenever possible, integrator.io will attempt to run your flow precisely when it’s scheduled. That said, it’s not uncommon for a flow to be delayed slightly by other factors, common to cloud-based applications. Try checking to see whether any of the following conditions might apply:
- Other flows might be running at the same time.
- Another automated task is currently being performed at a source app, such as SuiteScript in NetSuite.
- Finally, high internet traffic at the endpoint or integrator.io servers.
Any late start should have no effect on a delta flow, the next (dependent) scheduled flow, or the next run of the same flow.
